s'authentifier
version française rss feed
inria-00555008, version 1
Argument filterings and usable rules in higher-order rewrite systems
Sho Suzuki () a1, Keiichirou Kusakari () a1, Frédéric Blanqui () 2
IPSJ Transactions on Programming 4, 2 (2011) 1-12
Résumé : The static dependency pair method is a method for proving the termination of higher-order rewrite systems a la Nipkow. It combines the dependency pair method introduced for first-order rewrite systems with the notion of strong computability introduced for typed lambda-calculi. Argument filterings and usable rules are two important methods of the dependency pair framework used by current state-of-the-art first-order automated termination provers. In this paper, we extend the class of higher-order systems on which the static dependency pair method can be applied. Then, we extend argument filterings and usable rules to higher-order rewriting, hence providing the basis for a powerful automated termination prover for higher-order rewrite systems.
  • Domaine : Informatique/Logique en informatique
  • Mots-clés : rewriting – higher-order – termination – lambda-calculus
  • inria-00555008, version 1
  • oai:hal.inria.fr:inria-00555008
  • Contributeur :
  • Soumis le : Mardi 20 Septembre 2011, 06:34:43
  • Dernière modification le : Mardi 20 Septembre 2011, 18:59:52
tous les articles de la base du CCSd...
