Trust in MDE Components: the DOMINO Experiment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A large number of modeling activities can be automatic or computer assisted. This automation ensures a more rapid and robust software development. However, engineers must ensure that the models have the properties required for the application. In order to tend towards this requirement, the DOMINO project (DOMaINs and methodological prOcess) proposes to use the socalled trustworthy Model-Driven Engineering (MDE) components and aims to provide a methodology for the validation and qualification of such components.
Baudry10a.pdf (90.69 Ko) Télécharger le fichier
inria-00555044 , version 1 (12-01-2011)
  • HAL Id : inria-00555044 , version 1
Benoit Baudry, Pierre Bazex, Jean-Charles Dalbin, Philippe Dhaussy, Hubert Dubois, et al.. Trust in MDE Components: the DOMINO Experiment. SD4RCES workshop in conjunction with SAFECOMP 2010, 2010, Vienna, Austria. ⟨inria-00555044⟩
504 Consultations
212 Téléchargements
