Supporting Feature Analysis with Runtime Annotations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
The dynamic analysis approach to feature identification describes a technique for capturing feature behavior and mapping it to source code. Major drawbacks of this approach are (1) large amounts of data and (2) lack of support for sub-method elements. In this paper we propose to leverage sub-method reflection to identify and model features. We perform an on-the-fly analysis resulting in annotating the operations participating in a feature's behavior with meta-data.The primary advantage of our annotation approach is that we obtain a fine-grained level of granularity while at the same time eliminating the need to retain and analyze large traces for feature analysis.
Denk07dFeatureAnnotationPCODA.pdf (94.2 Ko) Télécharger le fichier
inria-00555456 , version 1 (13-01-2011)
  • HAL Id : inria-00555456 , version 1
Marcus Denker, Orla Greevy, Oscar Nierstrasz. Supporting Feature Analysis with Runtime Annotations. 3rd International Workshop on Program Comprehension through Dynamic Analysis (PCODA 2007), 2007, Vancouver, Canada. pp.29--33. ⟨inria-00555456⟩
121 Consultations
59 Téléchargements
