Consistency preservation and crazy formulas in BMS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
We provide conditions under which seriality is preserved during an update in the BMS framework. We consider not only whether the entire updated model is serial but also whether its generated submodels are serial. We also introduce the notion of crazy formulas which are formulas such that after being publicly announced at least one of the agents' beliefs become inconsistent.
JELIA2008.pdf (256.98 Ko) Télécharger le fichier
inria-00556148 , version 1 (01-09-2013)
  • HAL Id : inria-00556148 , version 1
Guillaume Aucher. Consistency preservation and crazy formulas in BMS. Logics in artificial intelligence, 11th european conference (JELIA), Sep 2008, Dresden, Germany. ⟨inria-00556148⟩
103 Consultations
311 Téléchargements
