Musical instrument identification based on new boosting algorithm with probabilistic decisions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jun Wu
  • Fonction : Auteur
  • PersonId : 891099
Stanislaw Andrzej Raczynski
  • Fonction : Auteur
  • PersonId : 891100
Takuya Nishimoto
  • Fonction : Auteur
  • PersonId : 835790
Nobutaka Ono
  • Fonction : Auteur
  • PersonId : 891101
Shigeki Sagayama
  • Fonction : Auteur
  • PersonId : 835791
This paper describes a new approach in musical instrument identification, an important task in the field of Music Information Retrieval (MIR). It is based on our previously developed probabilistic model which approximates the input audio spectrogram with a mixture of Gaussians. The EM algorithm is used to estimate the model parameters and calculate our newly proposed Harmonic Temporal Timbre Energy Ratio and Harmonic Temporal Timbre Envelope Similarity features. We then use these features in a novel boosting algorithm to perform the instrument classification. Contrary to traditional boosting methods, like the very popular AdaBoost, our new method uses probabilistic decision-making for hypotheses in each iteration, which results in better noise handing and higher classification accuracy.
wu_CMMR11.pdf (65.55 Ko) Télécharger le fichier
inria-00562115 , version 1 (02-02-2011)
  • HAL Id : inria-00562115 , version 1
Jun Wu, Emmanuel Vincent, Stanislaw Andrzej Raczynski, Takuya Nishimoto, Nobutaka Ono, et al.. Musical instrument identification based on new boosting algorithm with probabilistic decisions. Int. Symp. on Computer Music Modeling and Retrieval (CMMR), Mar 2011, Bhubaneswar, India. ⟨inria-00562115⟩
140 Consultations
350 Téléchargements
