PORGY: Strategy-Driven Interactive Transformation of Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper investigates the use of graph rewriting systems as a modelling tool, and advocates the embedding of such systems in an interactive environment. One important application domain is the modelling of biochemical systems, where states are represented by port graphs and the dynamics is driven by rules and strategies. A graph rewriting tool's capability to interactively explore the features of the rewriting system provides useful insights into possible behaviours of the model and its properties. We describe PORGY, a visual and interactive tool we have developed to model complex systems using port graphs and port graph rewrite rules guided by strategies, and to navigate in the derivation history. We demonstrate via examples some functionalities provided by PORGY.
porgy-main.pdf (647.88 Ko) Télécharger le fichier
inria-00563249 , version 1 (04-02-2011)
Oana Andrei, Maribel Fernandez, Hélène Kirchner, Guy Melançon, Olivier Namet, et al.. PORGY: Strategy-Driven Interactive Transformation of Graphs. 6th International Workshop on Computing with Terms and Graphs (TERMGRAPH 2011), Apr 2011, Saarbrücken, Germany. pp.54-68, ⟨10.4204/EPTCS.48.7⟩. ⟨inria-00563249⟩
375 Consultations
436 Téléchargements
