Optimized late binding: the SmallEiffel example - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 1999
Poster showing late binding mecanisms as implemented in the SmallEiffel compiler.
oopsla1999poster_abstract.pdf (80.28 Ko) Télécharger le fichier
inria-00563279 , version 1 (04-02-2011)
  • HAL Id : inria-00563279 , version 1
Olivier Zendra, Dominique Colnet. Optimized late binding: the SmallEiffel example. Object-Oriented Programming, Systems, Languages, and Applications (OOPSLA), 1999, Denver, United States. ⟨inria-00563279⟩
95 Consultations
62 Téléchargements
