Minimalist Grammars in the Light of Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
In this paper, we aim at understanding the derivations of minimalist grammars without the shortest move constraint. This leads us to study the relationship of those derivations with logic. In particular we show that the membership problem of minimalist grammars without the shortest move constraint is as difficult as provability in Multiplicative Exponential Linear Logic. As a byproduct, this result gives us a new representation of those derivations with linear $\lambda$-terms. We show how to interpret those terms in a homomorphic way so as to recover the sentence they analyse. As the homorphisms we describe are rather evolved, we turn to a proof-net representation and explain how Monadic Second Order Logic and related techniques allow us both to define those proof-nets and to retrieve the sentence they analyse.
syntax.pdf (293.39 Ko) Télécharger le fichier
inria-00563807 , version 1 (08-02-2011)
  • HAL Id : inria-00563807 , version 1
Sylvain Salvati. Minimalist Grammars in the Light of Logic. [Research Report] 2011, pp.39. ⟨inria-00563807⟩
188 Consultations
376 Téléchargements
