Learning Unions of Orthonormal Bases with Thresholded Singular Value Decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We propose a new method to learn overcomplete dictionaries for sparse coding structured as unions of orthonormal bases. The interest of such a structure is manifold. Indeed, it seems that many signals or images can be modeled as the superimposition of several layers with sparse decompositions in as many bases. Moreover, in such dictionaries, the efficient Block Coordinate Relaxation (BCR) algorithm can be used to compute sparse decompositions. We show that it is possible to design an iterative learning algorithm that produces a dictionary with the required structure. Each step is based on the coefficients estimation, using a variant of BCR, followed by the update of one chosen basis, using Singular Value Decomposition. We assess experimentally how well the learning algorithm recovers dictionaries that may or may not have the required structure, and to what extent the noise level is a disturbing factor.
2005_ICASSP_LesageGribonval_UnionSVD.pdf (154.14 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00564483 , version 1 (09-02-2011)
Sylvain Lesage, Rémi Gribonval, Frédéric Bimbot, Laurent Benaroya. Learning Unions of Orthonormal Bases with Thresholded Singular Value Decomposition. Acoustics, Speech and Signal Processing, 2005. ICASSP 2005. IEEE International Conference on, Mar 2005, Philadelphia, PA, United States. pp.V/293--V/296, ⟨10.1109/ICASSP.2005.1416298⟩. ⟨inria-00564483⟩
357 Consultations
1137 Téléchargements
