Extracting a data flow analyser in constructive logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2005
David Cachera
Thomas Jensen
  • Fonction : Auteur
  • PersonId : 874110
David Pichardie
A constraint-based data flow analysis is formalised in the specification language of the Coq proof assistant. This involves defining a dependent type of lattices together with a library of lattice functors for modular construction of complex abstract domains. Constraints are represented in a way that allows for both efficient constraint resolution and correctness proof of the analysis with respect to an operational semantics. The proof of existence of a solution to the constraints is constructive which means that the extraction mechanism of Coq provides a provably correct data flow analyser in Ocaml from the proof. The library of lattices and the representation of constraints are defined in an analysis-independent fashion that provides a basis for a generic framework for proving and extracting static analysers in Coq.
extract-tcs.pdf (240.52 Ko) Télécharger le fichier
inria-00564611 , version 1 (09-02-2011)
David Cachera, Thomas Jensen, David Pichardie, Vlad Rusu. Extracting a data flow analyser in constructive logic. Theoretical Computer Science, 2005, 342 (1), pp.56-78. ⟨10.1016/j.tcs.2005.06.004⟩. ⟨inria-00564611⟩
341 Consultations
141 Téléchargements
