Why to do Without Model Driven Architecture in Embedded System Codesign? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
The Model-Driven architecture is an initiative by the Object Management Group (OMG) to define an approach to software development based on modeling and automated mapping of models to implementations. The basic MDA pattern involves the definition of a platform-independent model (PIM) and its automated mapping to one or more platform-specific models (PSMs). par By defining different PIM and PSM dedicated to embedded systems, we will show the benefits of using the MDA approach in System on Chip codesign. From UML~2.0 profiles to System C or VHDL codes, the same model transformation engine is used with different rules expressed in XML.
Fichier non déposé
inria-00565174 , version 1 (11-02-2011)
  • HAL Id : inria-00565174 , version 1
Jean-Luc Dekeyser, Philippe Marquet, Samy Meftali, Cédric Dumoulin, Pierre Boulet, et al.. Why to do Without Model Driven Architecture in Embedded System Codesign?. The first annual IEEE BENELUX/DSP Valley Signal Processing Symposium, (SPS-DARTS 2005), 2005, Antwerp, Belgium. ⟨inria-00565174⟩
96 Consultations
0 Téléchargements
