Visual Data-parallel Programming for Signal Processing Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
Matrix manipulation programs are easily developed using a visual language. For signal processing, a graph of tasks operates on arrays. Each task iterates the same code on different patterns tilling these arrays. In this case visual specifications of dependencies between the pattern elements are enough to define an application. From the Array-OL language developed by Thomson Marconi Sonar, we propose a graphical environment, Gaspard, dedicated to the data-parallel paradigm. Only elementary SPMD tasks are textual. A full environment has been implemented including the graphical editor, a code transformer and a code generator for SMP computers.
Fichier non déposé
inria-00565183 , version 1 (11-02-2011)
  • HAL Id : inria-00565183 , version 1
Pierre Boulet, Jean-Luc Dekeyser, Jean-Luc Levaire, Philippe Marquet, Julien Soula, et al.. Visual Data-parallel Programming for Signal Processing Applications. 9th Euromicro Workshop on Parallel and Distributed Processing, PDP 2001, 2001, Mantova, Italy. pp.105--112. ⟨inria-00565183⟩
108 Consultations
0 Téléchargements
