Practical multi-candidate election system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2001
The aim of electronic voting schemes is to provide a set of protocols that allow voters to cast ballots while a group of authorities collect the votes and output the final tally. In this paper we describe a practical multi-candidate election scheme that guarantees privacy of voters, public verifiablity and robustness against a coalition of malicious authorities. Furthermore, we address the problem of receipt-freeness and incoercibility of voters. Our new scheme is based on the Paillier cryptosystem and on some related zero-knowledge proof techniques. The voting schemes are very practical and can be efficiently implemented in a real system.
podc01.pdf (175.23 Ko) Télécharger le fichier
inria-00565273 , version 1 (11-02-2011)
Olivier Baudron, Pierre-Alain Fouque, David Pointcheval, Jacques Stern, Guillaume Poupard. Practical multi-candidate election system. Proceedings of the Twentieth Annual ACM Symposium on Principles of Distributed Computing : PODC 2001, 2001, Newport, Rhode Island, United States. pp.274-283, ⟨10.1145/383962.384044⟩. ⟨inria-00565273⟩
235 Consultations
832 Téléchargements
