s'authentifier
version française rss feed
inria-00566246, version 1
Dodging Non-Uniform I/O Access in Hierarchical Collective Operations for Multicore Clusters
Brice Goglin () 12, Stéphanie Moreaud () a12
CASS 2011: The 1st Workshop on Communication Architecture for Scalable Systems, held in conjunction with IPDPS 2011 (2011) 7p
Résumé : The increasing number of cores led to scalability issues in modern servers that were addressed by using non-uniform memory interconnects such as HyperTransport and QPI. These technologies reintroduced Non-Uniform Memory Access (NUMA) architectures. They are also responsible for Non-Uniform Input/Output Access (NUIOA), as I/O devices may be directly connected to a single processor, thus getting faster access to some cores and memory banks than to the others. In this paper, we propose to adapt MPI collective operations to NUIOA constraints. These operations are now often based on the combination of multiple strategies depending on the underlying cluster topology, with local leader processes being used as intermediate. Our strategy focuses on electing these leaders according to the locality of processes and network interfaces so as to give them privileged network access. We validate our approach on a hierarchical Broadcast operation which brings up to 25% throughput improvement between 64 processes.
  • Collaboration : NUIOA hwloc Grid'5000 PLAFRIM
  • Domaine : Informatique/Système d'exploitation
  • inria-00566246, version 1
  • oai:hal.inria.fr:inria-00566246
  • Contributeur :
  • Soumis le : Mercredi 16 Février 2011, 15:01:36
  • Dernière modification le : Lundi 6 Mai 2013, 21:40:04
tous les articles de la base du CCSd...
