Multi-Source TDOA estimation using SNR-based angular spectra - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper deals with the localization of multiple sources from two-channel mixtures recorded in a reverberant environment. We introduce new angular spectrum-based methods relying on the signal-to-noise ratio (SNR) to estimate the time difference of arrival (TDOA) of each source. We propose and compare five ways of estimating the SNR in each time-frequency point and in each direction, using beamforming techniques and statistical models. Large-scale evaluation considering a high number of situations shows the effectiveness of the proposed approach compared to state-of-the-art angular spectrum-based techniques.
blandin_ICASSP11.pdf (137 Ko) Télécharger le fichier
inria-00566706 , version 1 (16-02-2011)
inria-00566706 , version 2 (10-05-2011)
inria-00566706 , version 3 (06-03-2012)
  • HAL Id : inria-00566706 , version 3
Charles Blandin, Emmanuel Vincent, Alexey Ozerov. Multi-Source TDOA estimation using SNR-based angular spectra. 2011 IEEE Int. Conf. on Acoustics, Speech and Signal Processing (ICASSP), May 2011, Prague, Czech Republic. pp.2616 - 2619. ⟨inria-00566706v3⟩
657 Consultations
525 Téléchargements
