Evolutionary Robotics: Exploring New Horizons - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2011
This paper considers the field of Evolutionary Robotics (ER) from the perspective of its potential users: roboticists. The core hypothesis motivating this field of research is discussed, as well as the potential use of ER in a robot design process. Four main aspects of ER are presented: (a) ER as an automatic parameter tuning procedure, which is the most mature application and is used to solve real robotics problem, (b) evolutionary-aided design, which may benefit the designer as an efficient tool to build robotic systems (c) ER for online adaptation, i.e. continuous adaptation to changing environment or robot features and (d) automatic synthesis, which corresponds to the automatic design of a mechatronic device and its control system. Critical issues are also presented as well as current trends and pespectives in ER. A section is devoted to a roboticist's point of view and the last section discusses the current status of the field and makes some suggestions to increase its maturity.
ER2011positionER.pdf (1.4 Mo) Télécharger le fichier
inria-00566896 , version 1 (17-02-2011)
  • HAL Id : inria-00566896 , version 1
Stéphane Doncieux, Jean-Baptiste Mouret, Nicolas Bredeche, Vincent Padois. Evolutionary Robotics: Exploring New Horizons. Springer Series: Studies in Computational Intelligence. New Horizons in Evolutionary Robotics, Springer, pp.3-25, 2011. ⟨inria-00566896⟩
400 Consultations
1271 Téléchargements
