inria-00567850, version 1
Autonomous 3D object modeling by a humanoid using an optimization-driven Next-Best-View formulation
Torea Foissotte 1, 2Olivier Stasse
1Pierre-Brice Wieber
a, 3Adrien Escande 4Abderahmanne Kheddar
1, 2
International Journal of Humanoid Robotics 7, 3 (2010) 407--428
Résumé : An original method to build a visual model for unknown objects by a humanoid robot is proposed. The algorithm ensures successful autonomous realization of this goal by addressing the problem as an active coupling between computer vision and whole-body posture generation. The visual model is built through the repeated execution of two processes. The first one considers the current knowledge about the visual aspects and the shape of the object to deduce a preferred viewpoint with the aim of reducing the uncertainty of the shape and appearance of the object. This is done while considering the constraints related to the embodiment of the vision sensors in the humanoid head. The second process generates a whole robot posture using the desired head pose while solving additional constraints such as collision avoidance and joint limitations. The main contribution of our approach relies on the use of different optimization algorithms to find an optimal viewpoint by including the humanoid specificities in terms of constraints, an embedded vision sensor, and redundant motion capabilities. This approach differs significantly from those of traditional works addressing the problem of autonomously building an object model.
- a – INRIA
- 1 : Joint Robotics Laboratory AIST & CNRS (JRL)
- AIST – CNRS : UMI3218
- 2 : Laboratoire d'Informatique de Robotique et de Microélectronique de Montpellier (LIRMM)
- CNRS : UMR5506 – Université Montpellier II - Sciences et Techniques du Languedoc
- 3 : BIPOP (INRIA Grenoble Rhône-Alpes / LJK Laboratoire Jean Kuntzmann)
- INRIA – Laboratoire Jean Kuntzmann
- 4 : Laboratoire d'Intégration des Systèmes et des Technologies (CEA LIST)
- CEA : DRT/LIST
- Domaine : Informatique/Robotique
- inria-00567850, version 1
- http://hal.inria.fr/inria-00567850
- oai:hal.inria.fr:inria-00567850
- Contributeur : Pierre-Brice Wieber
- Soumis le : Mardi 22 Février 2011, 09:18:42
- Dernière modification le : Vendredi 25 Février 2011, 14:24:23
Documents associés
Exporter
