Harnessing the Power of GPUs without Losing Abstractions in SaC and ArrayOL: A Comparative Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Over recent years, using Graphics Processing Units (GPUs) has become as an effective method for increasing the performance of many applications. However, these performance benefits from GPUs come at a price. Firstly extensive programming expertise and intimate knowledge of the underlying hardware are essential for gaining good speedups. Secondly, the expressibility of GPU-based programs are not powerful enough to retain the high-level abstractions of the solutions. Although the programming experience has been significantly improved by existing frameworks like CUDA and OpenCL, it is still a challenge to effectively utilise these devices while still retaining the programming abstractions. To this end, performing a source-to-source transformation, whereby a high-level language is mapped to CUDA or OpenCL, is an attractive option. In particular, it enables one to retain high-level abstractions and to harness the power of GPUs without any expertise on the GPGPU programming. In this paper, we compare and analyse two such schemes. One of them is a transformation mechanism for mapping a image/signal processing domain-specific language, ArrayOL, to OpenCL. The other one is a transformation route for mapping a high-level general purpose array processing language, Single Assignment C (SaC) to CUDA. Using a real-world image processing application as a running example, we demonstrate that albeit the fact of being general purpose, the array processing language be used to specify complex array access patterns generically. Performance of the generated CUDA code is comparable to the OpenCL code created from domain-specific language.
Mots clés
paper.pdf (1.13 Mo) Télécharger le fichier
inria-00569100 , version 1 (24-02-2011)
  • HAL Id : inria-00569100 , version 1
Jing Guo, Antonio Wendell de Oliveira Rodrigues, Jerarajan Thiyagalingam, Frédéric Guyomarch, Pierre Boulet, et al.. Harnessing the Power of GPUs without Losing Abstractions in SaC and ArrayOL: A Comparative Study. HIPS 2011, 16th International Workshop on High-Level Parallel Programming Models and Supportive Environments, May 2011, Anchorage (Alaska), United States. ⟨inria-00569100⟩
252 Consultations
220 Téléchargements
