A granular approach for the analysis of monophonic audio signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper describes a method for analyzing audio signals with an adaptive ``parametric dictionary''. We use sliding frames to extract elementary signals or grains from the anal- ysis signal. We search for similarities amongst the collected grains to form classes, which we then use to derive a signal model for each class. These signal models or prototypes, are used to decompose the audio signal and compute analysis parameters for each grain. As a preliminary evaluation, we tested the method with real-life, monophonic and monaural recordings and obtained encouraging results.
06-00469.pdf (343.6 Ko) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00574785 , version 1 (08-03-2011)
Lorcan Mcdonagh, Frédéric Bimbot, Rémi Gribonval. A granular approach for the analysis of monophonic audio signals. IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP 2003), Apr 2003, Hong-Kong, Hong Kong SAR China. pp.VI/469--VI/472, ⟨10.1109/ICASSP.2003.1201720⟩. ⟨inria-00574785⟩
150 Consultations
178 Téléchargements
