Control-flow analysis of function call and returns by abstract interpretation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We derive a control-flow analysis that approximates the interproce- dural control-flow of both function calls and returns in the presence of first-class functions and tail-call optimization. In addition to an abstract environment, our analysis computes for each expression an abstract control stack, effectively approximating where func- tion calls return across optimized tail calls. The analysis is sys- tematically calculated by abstract interpretation of the stack-based CaEK abstract machine of Flanagan et al. using a series of Galois connections. Abstract interpretation provides a unifying setting in which we 1) prove the analysis equivalent to the composition of a continuation-passing style (CPS) transformation followed by an abstract interpretation of a stack-less CPS machine, and 2) extract an equivalent constraint-based formulation, thereby providing a ratio- nal reconstruction of a constraint-based control-flow analysis from abstract interpretation principles.
ICFP09-ANFCFA.pdf (177.79 Ko) Télécharger le fichier
inria-00574944 , version 1 (09-03-2011)
Jan Midtgaard, Thomas Jensen. Control-flow analysis of function call and returns by abstract interpretation. ACM International Conference on Functional Programming, Sep 2009, Edinburgh, United Kingdom. ⟨10.1145/1596550.1596592⟩. ⟨inria-00574944⟩
227 Consultations
308 Téléchargements
