Fast Matching Pursuit with a multiscale dictionary of Gaussian Chirps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Signal Processing Année : 2001
We introduce a modified matching pursuit algorithm, called fast ridge pursuit, to approximate N-dimensional signals with M Gaussian chirps at a computational cost O(MN) instead of the expected O(MN^2 log N). At each iteration of the pursuit, the best Gabor atom is first selected, and then, its scale and chirp rate are locally optimized so as to get a “good” chirp atom, i.e., one for which the correlation with the residual is locally maximized. A ridge theorem of the Gaussian chirp dictionary is proved, from which an estimate of the locally optimal scale and chirp is built. The procedure is restricted to a sub-dictionary of local maxima of the Gaussian Gabor dictionary to accelerate the pursuit further. The efficiency and speed of the method is demonstrated on a sound signal.
2001_IEEE_TSP_Gribonval_Chirps.pdf (1.67 Mo) Télécharger le fichier
Origine : Accord explicite pour ce dépôt
inria-00576201 , version 1 (13-03-2011)
Rémi Gribonval. Fast Matching Pursuit with a multiscale dictionary of Gaussian Chirps. IEEE Transactions on Signal Processing, 2001, 49 (5), pp.994-1001. ⟨10.1109/78.917803⟩. ⟨inria-00576201⟩
314 Consultations
592 Téléchargements
