Audio source separation with one sensor for robust speech recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
In this paper, we address the problem of noise compensation in speech signals for robust speech recognition. Several classical denoising methods in the field of speech and signal processing are compared on speech corrupted by music, which correspond to a frequent situation in broadcast news transcription tasks. We also present two new source separation techniques, namely adaptive Wiener filtering and adaptive shrinkage. These techniques rely on the use of a dictionary of spectral shapes to deal with the non stationarity of the signals. The algorithms are first compared on the source separation task and assessed in terms of average distortion. Their effect on the entire transcription system is eventually compared in terms of word error rate. Results show that the proposed adaptive Wiener filter approach yields a significant improvement of the transcription accuracy at signal/noise ratios greater than 15 dB.
benaroya-nolisp-03.pdf (368.69 Ko) Télécharger le fichier
inria-00576210 , version 1 (13-03-2011)
  • HAL Id : inria-00576210 , version 1
Laurent Benaroya, Frédéric Bimbot, Guillaume Gravier, Rémi Gribonval. Audio source separation with one sensor for robust speech recognition. ISCA Tutorial and Research Workshop on Non-Linear Speech Processing (NOLISP), IRISA, May 2003, Le Croisic, France. ⟨inria-00576210⟩
173 Consultations
83 Téléchargements
