Sequential Minimal Eigenvalues - An Approach to Analysis Dictionary Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Michael Elad
  • Fonction : Auteur
  • PersonId : 892779
Nancy Bertin
Mark D. Plumbley
  • Fonction : Auteur
  • PersonId : 871792
Over the past decade there has been a great interest in asynthesis-based model for signals, based on sparse and re-dundant representations. Such a model assumes that the sig-nal of interest can be decomposed as a linear combinationof few columns from a given matrix (the dictionary). An al-ternative, analysis-based, model can be envisioned, where ananalysis operator multiplies the signal, leading to a sparseoutcome. In this paper we propose a simple but effectiveanalysis operator learning algorithm, where analysis "atoms"are learned sequentially by identifying directions that are or-thogonal to a subset of the training data. We demonstratethe effectiveness of the algorithm in three experiments, treat-ing synthetic data and real images, showing a successful andmeaningful recovery of the analysis operator.
EUSIPCO2011_Analysis_Training.pdf (376.96 Ko) Télécharger le fichier
inria-00577231 , version 1 (15-09-2011)
  • HAL Id : inria-00577231 , version 1
Boaz Ophir, Michael Elad, Nancy Bertin, Mark D. Plumbley. Sequential Minimal Eigenvalues - An Approach to Analysis Dictionary Learning. The 19th European Signal Processing Conference (EUSIPCO‐2011), Aug 2011, Barcelona, Spain. ⟨inria-00577231⟩
347 Consultations
172 Téléchargements
