Generalized Multifractional Brownian Motion: Definition and Preliminary Results - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 1999
The Multifractional Brownian Motion (MBM) is a generalization of the well known Fractional Brownian Motion. One of the main reasons that makes the MBM interesting for modelization, is that one can prescribe its regularity: given any Hölder function H(t), with values in ]0,1[, one can construct an MBM admitting at any t0, a Hölder exponent equal to H(t0). However, the continuity of the function H(t) is sometimes undesirable, since it restricts the field of application. In this work we define a gaussian process, called the Generalized Multifractional Brownian Motion (GMBM) that extends the MBM. This process will also depend on a functional parameter H(t) that belongs to a set , but will be much more larger than the space of Hölder functions.
Generalized_Multifractional_Brownian_Motion_Definition_and_Preliminary_Results.pdf (6.3 Mo) Télécharger le fichier
inria-00578657 , version 1 (21-03-2011)
  • HAL Id : inria-00578657 , version 1
Antoine Ayache, Jacques Lévy Véhel. Generalized Multifractional Brownian Motion: Definition and Preliminary Results. M. Dekking, J. Lévy Véhel, E. Lutton and C. Tricot. Fractals - Theory and Applications in Engineering, Springer, 1999. ⟨inria-00578657⟩
Collections
INRIA INRIA2
211 Consultations
291 Téléchargements
