Multiple Congruence Relations, First-Order Theories on Terms, and the Frames of the Applied Pi-Calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We investigate the problem of deciding first-order theories of finite trees with several distinguished congruence relations, each of them given by some equational axioms. We give an automata-based solution for the case where the different equational axiom systems are linear and variable-disjoint (this includes the case where all axioms are ground), and where the logic does not permit to express tree relations x=f(y,z). We show that the problem is undecidable when these restrictions are relaxed. As motivation and application, we show how to translate the model-checking problem of Apil, a spatial equational logic for the applied pi-calculus, to the validity of first-order formulas in term algebras with multiple congruence relations.
tosca.pdf (372.73 Ko) Télécharger le fichier
inria-00578896 , version 1 (22-03-2011)
Florent Jacquemard, Etienne Lozes, Ralf Treinen, Jules Villard. Multiple Congruence Relations, First-Order Theories on Terms, and the Frames of the Applied Pi-Calculus. Theory of Security and Applications (TOSCA, joint workshop affiliated to ETAPS), Mar 2011, Saarbrücken, Germany. pp.166-185, ⟨10.1007/978-3-642-27375-9⟩. ⟨inria-00578896⟩
245 Consultations
186 Téléchargements
