inria-00580122, version 5
Differential Privacy: on the trade-off between Utility and Information Leakage
Mário S. Alvim
1Miguel E. Andrés 1Konstantinos Chatzikokolakis 1Pierpaolo Degano 2Catuscia Palamidessi
1
The 8th International Workshop on Formal Aspects of Security & Trust (FAST) (2011)
Résumé : Differential privacy is a notion of privacy that has become very popular in the database community. Roughly, the idea is that a randomized query mechanism provides sufficient privacy protection if the ratio between the probabilities that two adjacent datasets give the same answer is bound by $e^\epsilon$. In the field of information flow there is a similar concern for controlling information leakage, i.e. limiting the possibility of inferring the secret information from the observables. In recent years, researchers have proposed to quantify the leakage in terms of Rényi min mutual information, a concept strictly related to the Bayes risk. In this paper, we show how to model the query system in terms of an information-theoretic channel, and we compare the notion of differential privacy with that of mutual information. We show that differential privacy implies a bound on the mutual information. Furthermore, we show that our bound is tight. Then, we consider the utility of the randomization mechanism, which represents how close the randomized answers are, in average, to the real ones. We show that the notion of differential privacy implies a bound on utility, also tight, and we propose a method that under certain conditions builds an optimal randomization mechanism, i.e. a mechanism which provides the best utility while guaranteeing differential privacy.
- 1 : COMETE (INRIA Saclay - Ile de France)
- INRIA – Polytechnique - X – CNRS : UMR7161
- 2 : Dipartimento di Informatica [Pisa] (DI)
- University of Pisa
- Domaine : Informatique/Logique en informatique
- Versions disponibles : v1 (27-03-2011) v2 (09-05-2011) v3 (24-08-2011) v4 (28-08-2011) v5 (30-09-2011)
- inria-00580122, version 5
- http://hal.inria.fr/inria-00580122
- oai:hal.inria.fr:inria-00580122
- Contributeur : Catuscia Palamidessi
- Soumis le : Vendredi 30 Septembre 2011, 03:47:42
- Dernière modification le : Lundi 3 Octobre 2011, 00:23:19
Documents associés
Exporter
