User-Feature Model for Hybrid Recommender System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recommender systems provide relevant items to users from a large number of choices. In this work, we are interested in personalized recommender systems where user model is based on an analysis of usage. Collaborative filtering and content-based filtering are the most widely used techniques in personalized recommender systems. Each technique has its drawbacks, so hybrid solutions, combining the two techniques, have emerged to overcome their disadvantages and benefit from their strengths. In this paper, we propose a hybrid solution combining collaborative filtering and content-based filtering. With this aim, we have defined a new user model, called user- feature model, to model user preferences based on items' features and user ratings. The user-feature model is built from the user item model by using a fuzzy clustering algorithm: the Fuzzy C Mean (FCM) algorithm. Then, we used the user-feature model in a user-based collaborative filtering algorithm to calculate the similarity between users. Applying our approach to the MoviesLens dataset, significant improvement can be noticed comparatively to the main CF algorithm, denoted as user-based collaborative filtering.
Web
siie2011_submission_68.pdf (895.64 Ko) Télécharger le fichier
inria-00580523 , version 1 (28-03-2011)
  • HAL Id : inria-00580523 , version 1
Sonia Ben Ticha, Azim Roussanaly, Anne Boyer, Khaled Bsaies. User-Feature Model for Hybrid Recommender System. 4th International Conference on Information Systems and Economic Intelligence - SIIE'2011, IGA, Casablanca Maroc, Mar 2011, Marrakech, Morocco. ⟨inria-00580523⟩
318 Consultations
1041 Téléchargements
