inria-00581259, version 1
Global State Estimates for Distributed Systems
Gabriel Kalyon 1Tristan Le Gall 2Hervé Marchand
a, 3Thierry Massart 1
31th IFIP International Conference on FORmal TEchniques for Networked and Distributed Systems. 6722 (2011) 198-212
Résumé : We consider distributed systems modeled as communicating finite state machines with reliable unbounded FIFO channels. As an essential sub-routine for control, monitoring and diagnosis applications, we provide an algorithm that computes, during the execution of the system, an estimate of the current global state of the distributed system for each local subsystem. This algorithm does not change the behavior of the system; each subsystem only computes and records a symbolic representation of the state estimates, and piggybacks some extra information to the messages sent to the other subsystems in order to refine their estimates. Our algorithm relies on the computation of reachable states. Since the reachability problem is undecidable in our model, we use abstract interpretation techniques to obtain regular overapproximations of the possible FIFO channel contents, and hence of the possible current global states. An implementation of this algorithm provides an empirical evaluation of our method.
- a – INRIA
- 1 : Université Libre de Bruxelles (ULB)
- Université Libre de Bruxelles
- 2 : Laboratoire d'Intégration des Systèmes et des Technologies (CEA LIST)
- CEA : DRT/LIST
- 3 : VERTECS (INRIA)
- INRIA
- Domaine : Informatique/Génie logiciel
- inria-00581259, version 1
- http://hal.inria.fr/inria-00581259
- oai:hal.inria.fr:inria-00581259
- Contributeur : Hervé Marchand
- Soumis le : Mercredi 30 Mars 2011, 15:15:17
- Dernière modification le : Jeudi 29 Septembre 2011, 09:34:26
Documents associés
Exporter
