A spatial Poisson Point Process to classify coconut fields on Ikonos pansharpened images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
The goal of this study is to classify the coconut fields, observed on remote sensing images, according to their spatial distribution. For that purpose, we use a technique of point pattern analysis to characterize spatially a set of points. These points are obtained after a coconut trees segmentation process on Ikonos images. Coconuts' fields not following a Poisson Point Process are identified as maintained, otherwise other fields are characterized as wild. A spatial analysis is then used to establish locally the Poisson intensity and therefore to characterize the degree of wildness.
Fichier non déposé
inria-00582390 , version 1 (01-04-2011)
Raimana Teina, Dominique Béréziat, Benoît Stoll. A spatial Poisson Point Process to classify coconut fields on Ikonos pansharpened images. SPIE Asia Pacific Remote Sensing, Nov 2008, Nouméa, New Caledonia. pp.71491E, ⟨10.1117/12.806422⟩. ⟨inria-00582390⟩
95 Consultations
0 Téléchargements
