inria-00583669, version 1
Impacts of Invariance in Search: When CMA-ES and PSO Face Ill-Conditioned and Non-Separable Problems
Nikolaus Hansen
1, 2, 3Raymond Ros
a, 1Nikolas Mauny 1Marc Schoenauer
1, 2Anne Auger
1
Applied Soft Computing 11 (2011) 5755-5769
Résumé : This paper investigates the behavior of PSO (particle swarm optimization) and CMA-ES (covariance matrix adaptation evolution strategy) on ill-conditioned functions. The paper also highlights momentum as important common concept used in both algorithms and reviews important invariance properties. On \emph{separable}, ill-conditioned functions, PSO performs very well and outperforms CMA-ES by a factor of up to five. On the same but rotated functions, the performance of CMA-ES is unchanged, while the performance of PSO declines dramatically: on \emph{non-separable}, ill-conditioned functions we find the search costs (number of function evaluations) of PSO increasing roughly proportional with the condition number and CMA-ES outperforms PSO by orders of magnitude. The strong dependency of PSO on rotations originates from random events that are only independent within the given coordinate system. The CMA-ES adapts the coordinate system where the independent events take place and is rotational invariant. We argue that invariance properties, like rotational invariance, are desirable, because they increase the predictive power of performance results by inducing problem equivalence classes.
- a – Université Paris Sud - Paris XI
- 1 : TAO (INRIA Saclay - Ile de France)
- INRIA – CNRS : UMR8623 – Université Paris XI - Paris Sud
- 2 : Laboratoire de Recherche en Informatique (LRI)
- CNRS : UMR8623 – Université Paris XI - Paris Sud
- 3 : Microsoft Research - Inria Joint Centre (MSR - INRIA)
- INRIA – Microsoft – Microsoft Research Laboratory Cambridge
- Domaine : Informatique/Apprentissage
- inria-00583669, version 1
- http://hal.inria.fr/inria-00583669
- oai:hal.inria.fr:inria-00583669
- Contributeur : Nikolaus Hansen
- Soumis le : Mercredi 6 Avril 2011, 11:40:46
- Dernière modification le : Vendredi 30 Septembre 2011, 16:38:09
Documents associés
Exporter
