An Isogeometric Analysis Approach for the study of the gyrokinetic quasi-neutrality equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2012
In this work, a new discretization scheme of the gyrokinetic quasi-neutrality equation is proposed. It is based on Isogeometric Analysis; the IGA which relies on NURBS functions, seems to accommodate arbitrary coordinates and the use of complicated computation domains. Moreover, arbitrary high order degree of basis functions can be used. Here, this approach is successfully tested on elliptic problems like the quasi-neutrality equation.
qn-nurbs-crous-ratnani-sonnen.pdf (973 Ko) Télécharger le fichier
inria-00584672 , version 1 (09-04-2011)
Nicolas Crouseilles, Ahmed Ratnani, Eric Sonnendrücker. An Isogeometric Analysis Approach for the study of the gyrokinetic quasi-neutrality equation. Journal of Computational Physics, 2012, 231 (2), pp.373-393. ⟨10.1016/j.jcp.2011.09.004⟩. ⟨inria-00584672⟩
365 Consultations
392 Téléchargements
