Wet paper codes and the dual distance in steganography - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Mathematics of Communications Année : 2011
Carlos Munuera
  • Fonction : Auteur
  • PersonId : 898945
Morgan Barbier
In 1998 Crandall introduced a method based on coding theory to secretly embed a message in a digital support such as an image. Later Fridrich et al. improved this method to minimize the distortion introduced by the embedding; a process called wet paper. However, as previously emphasized in the literature, this method can fail during the embedding step. Here we find sufficient and necessary conditions to guarantee a successful embedding by studying the dual distance of a linear code. Since these results are essentially of combinatorial nature, they can be generalized to systematic codes, a large family containing all linear codes. We also compute the exact number of solutions and point out the relationship between wet paper codes and orthogonal arrays.
Steganography_and_the_dual_distance.pdf (197.27 Ko) Télécharger le fichier
inria-00584877 , version 1 (11-04-2011)
Carlos Munuera, Morgan Barbier. Wet paper codes and the dual distance in steganography. Advances in Mathematics of Communications, 2011, Lecture Notes on Computer Sciences, 6 (3), pp.273-285. ⟨10.3934/amc.2012.6.273⟩. ⟨inria-00584877⟩
193 Consultations
204 Téléchargements
