Intermediate CONNECT Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Interoperability remains a fundamental challenge when connecting heterogeneous systems which encounter and spontaneously communicate with one another in pervasive computing environments. This challenge is exasperated by the highly heterogeneous technologies employed by each of the interacting parties, i.e., in terms of hardware, operating system, middleware protocols, and application protocols. The key aim of the CONNECT project is to drop this heterogeneity barrier and achieve universal interoperability. Here we report on the activities of WP1 into developing the CONNECT architecture that will underpin this solution. In this respect, we present the following key contributions from the second year. Firstly, the intermediary CONNECT architecture that presents a more concrete view of the technologies and principles employed to enable interoperability between heterogeneous networked systems. Secondly, the design and implementation of the discovery enabler with emphasis on the approaches taken to match compatible networked systems. Thirdly, the realisation of CONNECTors that can be deployed in the environment; we provide domain specific language solutions to generate and translate between middleware protocols. Fourthly, we highlight the role of ontologies within CONNECT and demonstrate how ontologies crosscut all functionality within the CONNECT architecture.
Connect_WP1_D12.pdf (5.49 Mo) Télécharger le fichier
inria-00584911 , version 1 (02-05-2011)
  • HAL Id : inria-00584911 , version 1
Amel Bennaceur, Gordon S. Blair, Franck Chauvel, Nikolaos Georgantas, Paul Grace, et al.. Intermediate CONNECT Architecture. [Research Report] 2011. ⟨inria-00584911⟩
222 Consultations
229 Téléchargements
