Towards a Time-predictable Dual-Issue Microprocessor: The Patmos Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Current processors are optimized for average case performance, often leading to a high worst-case execution time (WCET). Many architectural features that increase the average case performance are hard to be modeled for the WCET analysis. In this paper we present Patmos, a processor optimized for low WCET bounds rather than high average case performance. Patmos is a dual- issue, statically scheduled RISC processor. The instruction cache is organized as a method cache and the data cache is organized as a split cache in order to simplify the cache WCET analysis. To fill the dual-issue pipeline with enough useful instructions, Patmos relies on a customized compiler. The compiler also plays a central role in optimizing the application for the WCET instead of average case performance.
schoeberl-ppes11.pdf (159.2 Ko) Télécharger le fichier
inria-00585320 , version 1 (12-04-2011)
Martin Schoeberl, Pascal Schleuniger, Wolfgang Puffitsch, Florian Brandner, Christian W. Probst, et al.. Towards a Time-predictable Dual-Issue Microprocessor: The Patmos Approach. Bringing Theory to Practice: Predictability and Performance in Embedded Systems, Philipp Lucas, Lothar Thiele, Benoit Triquet, Theo Ungerer, and Reinhard Wilhelm, Mar 2011, Grenoble, France. pp.11-21, ⟨10.4230/OASIcs.PPES.2011.11⟩. ⟨inria-00585320⟩
584 Consultations
712 Téléchargements
