Evolution of Ontologies and Types - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Ontologies are heavily used in the context of the Semantic Web (Berners-Lee 1998, 2001) to formalize human knowledge. Ontologies engineering is now an important activity, and specialized softwares are developed to help in managing huge ontologies. The development of ontologies and of information systems can be compared to the development of programs. In this paper we make a parallel between ontologies and types in programming languages, and we use a small example to show that an ontology can be seen as a type system. When an ontology evolves, studying the impact of this evolution on the semantic annotations that use this ontology can be viewed as a type-checking process. The next step should be to import some notions used in the types community as overloading, polymorphism, type parameters, etc. to improve or create more powerful ontology definition languages.
IADIS-td.pdf (51.52 Ko) Télécharger le fichier
inria-00586056 , version 1 (15-04-2011)
  • HAL Id : inria-00586056 , version 1
Thierry Despeyroux. Evolution of Ontologies and Types. IADIS International conference WWW/Internet 2008, IADIS, Oct 2008, Freiburg, Germany. ⟨inria-00586056⟩
Collections
INRIA INRIA2
98 Consultations
80 Téléchargements
