A Simple Layered RGB BRDF Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2002
Wolfgang Heidrich
  • Fonction : Auteur
  • PersonId : 836035
Many natural objects, and in general layered materials, have non-linear reflection behaviour along the wavelengths. An accurate representation of phenomena such as interference and colour separation generally requires a fine spectral representation of light instead of the commonly used RGB components. In this article, we introduce and experiment with a general approach to create similar and convincing effects, with a simple RGB BRDF model. We present a model for both specular and a diffuse reflection.
pg-127_granier_x.pdf (893.51 Ko) Télécharger le fichier
IRBRDF.ppt (2.97 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00586498 , version 1 (16-04-2011)
Xavier Granier, Wolfgang Heidrich. A Simple Layered RGB BRDF Model. 10th Pacific Conference on Computer Graphics and Applications, Oct 2002, Beijing, China. pp.30-37, ⟨10.1109/PCCGA.2002.1167836⟩. ⟨inria-00586498⟩
Relations
135 Consultations
1839 Téléchargements
