The CONNECT Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2011
Current solutions to interoperability remain limited with respect to highly dynamic and heterogeneous environments, where systems encounter one another spontaneously. In this chapter, we introduce the Connect architecture, which puts forward a fundamentally different method to tackle the interoperability problem. The philosophy is to observe networked systems in action, learn their behaviour and then dynamically generate mediator software which will connect two heterogeneous systems. We present a high-level overview of how Connect operates in practice and subsequently provide a simple example to illustrate the architecture in action.
ChapterConnectArchitecture.pdf (717.93 Ko) Télécharger le fichier
inria-00586638 , version 1 (18-04-2011)
Paul Grace, Nikolaos Georgantas, Amel Bennaceur, Gordon Blair, Franck Chauvel, et al.. The CONNECT Architecture. Marco Bernardo and Valerie Issarny. 11th International School on Formal Methods for the Design of Computer, Communication and Software Systems: Connectors for Eternal Networked Software Systems, 6659, Springer, pp.27-52, 2011, Lecture notes in computer science, 978-3-642-21454-7. ⟨10.1007/978-3-642-21455-4⟩. ⟨inria-00586638⟩
278 Consultations
177 Téléchargements
