Scheduling Multi Clock Real Time Systems: From Requirements to Implementation
This paper presents an approach for modeling simulating and analyzing multi clocks real time systems during the different steps of a design. These steps range from the first requirements to a model allocated on a specific execution platform. The \uml \marte profile and the \ccsl language are used together to specify the causal and temporal characteristics of the software as well as the hardware parts of the system. The \tsq environment allows a simulation of such specification and the detection of potential errors and deadlocks. When the specification refinement is finished, to prove the specification correctness, the \ccsl specification is used to generate a synchronous model and some observers in Esterel. We illustrate the approach through a spark ignition control system.
Systèmes embarqués
