RT-simex: retro-analysis of execution traces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This presentation demonstrates the early results from the French ANR project RT-Simex. RT-Simex proposes a set of tools to analyze timing of parallel embedded code and trace the simulation results back to the initial models from which the code was generated. The whole tool-set relies on standard formats (uml marte, Open Trace Format) to ensure a perennial use. This is achieved through the polychronous logical time model of marte.
Fichier non déposé
inria-00587116 , version 1 (19-04-2011)
Julien Deantoni, Frédéric Mallet, Frédéric Thomas, Gonzague Reydet, Jean-Philippe Babau, et al.. RT-simex: retro-analysis of execution traces. SIGSOFT FSE, Nov 2010, Santa Fe, United States. pp.377-378, ⟨10.1145/1882291.1882357⟩. ⟨inria-00587116⟩
272 Consultations
0 Téléchargements
