A k-layer self-organizing structure for product management in stock-based networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Traditional Distributed Hash Tables (DHT) abstraction distributes data items among peer nodes on a structured overlay network in storage-intensive applications. The question is whether DHT-based systems can provide reliable and scalable storage services also in stock-oriented applications, where logistics, traceability and fault-tolerance are the main requirements. In this paper a novel approach to self-organizing stock management networks, based on a two-level DHT mechanism is proposed and analyzed. Some preliminary results suggest that our method can reduce network traffic and achieve high data availability also in such storage and management networks.
SENSATION.pdf (502.3 Ko) Télécharger le fichier
inria-00587849 , version 1 (21-04-2011)
  • HAL Id : inria-00587849 , version 1
Aline Carneiro Viana, Nathalie Mitton, Loic Schmidt, Massimo Vecchio. A k-layer self-organizing structure for product management in stock-based networks. Proc. 7th IEEE International Conference on e-Business Engineering (ICEBE), Nov 2010, Shanghai, China. ⟨inria-00587849⟩
236 Consultations
136 Téléchargements
