Model-Based Strategy Planning for Recognizing Partially Occluded Parts
Recognizing partially occluded objects requires off-line modeling and planning, and runtime recognition. After deriving a customized method, we compare recognition with and without off-line planning.
HoraudSkordas_CompMag_87.pdf (191.26 Ko)
Télécharger le fichier
Format : Figure, Image
