An Analytic Solution for the Perspective 4-Point Problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1989
The perspective n-point (PnP) problem is the problem of finding the position and orientation of a camera with respect to a scene object from n correspondence points. The authors propose an analytic solution for the perspective 4-point problem. The solution is found by replacing the four points with a pencil of three lines and by exploring the geometric constraints available with the perspective camera model. The P4P problem is cast into the problem of solving a biquadratic polynomial equation in one unknown.
Horaud-CVPR89.pdf (138.15 Ko) Télécharger le fichier
inria-00589992 , version 1 (16-06-2011)
Radu Horaud, Bernard Conio, Olivier Leboulleux, Bernard Lacolle. An Analytic Solution for the Perspective 4-Point Problem. Proceedings Computer Vision and Pattern Recognition, Jun 1989, San-Diego, United States. pp.500--507, ⟨10.1109/CVPR.1989.37893⟩. ⟨inria-00589992⟩
162 Consultations
811 Téléchargements
