Symbolic Image Matching by Simulated Annealing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1990
In this paper we suggest an optimisation approach to visual matching. We assume that the information available in an image may be conveniently represented symbolically in a relational graph. We concentrate on the problem of matching two such graphs. First we derive a cost function associated with graph matching and more precisely associated with subgraph isomorphism and with maximum subgraph matching. This cost function is well suited for optimization methods such as simulated annealing. We show how the graph matching problem is easily cast into a simulated annealing algorithm. Finally we show some preliminary experimental results and discuss the utility of this graph matching method in computer vision in general.
HeraultHoraudBMVC90.pdf (141.67 Ko) Télécharger le fichier
inria-00589994 , version 1 (03-05-2011)
  • HAL Id : inria-00589994 , version 1
Laurent Hérault, Radu Horaud, Françoise Veillon, Jean-Jacques Niez. Symbolic Image Matching by Simulated Annealing. 4th British Machine Vision Conference (BMVC '90), Sep 1990, Oxford, United Kingdom. pp.319--324. ⟨inria-00589994⟩
232 Consultations
139 Téléchargements
