Object pose from 2-D to 3-D point and line correspondences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Computer Vision Année : 1995
In this paper we present a method for optimally estimating the rotation and translation between a camera and a 3-D object from point and/or line correspondences. First we devise an error function and second we show how to minimize this error function. The quadratic nature of this function is made possible by representing rotation and translation with a dual number quaternion. We provide a detailed account of the computational aspects of a trust-region optimization method. This method compares favourably with Newton's method which has extensively been used to solve the problem at hand, with Faugeras-Toscani's linear method (Faugeras and Toscani 1986) for calibrating a camera, and with the Levenberg-Marquardt non-linear optimization method. Finally we present some experimental results which demonstrate the robustness of our method with respect to image noise and matching errors.
PhongHoraud-IJCV95.pdf (411.23 Ko) Télécharger le fichier
inria-00590044 , version 1 (03-05-2011)
Thai-Quynh Phong, Radu Horaud, Adnan Yassine, Pham-Dinh Tao. Object pose from 2-D to 3-D point and line correspondences. International Journal of Computer Vision, 1995, 15 (3), pp.225--243. ⟨10.1007/BF01451742⟩. ⟨inria-00590044⟩
202 Consultations
634 Téléchargements
