Euclidean Shape and Motion from Multiple Perspective Views by Affine Iterations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Pattern Analysis and Machine Intelligence Année : 1996
In this paper we describe a method for solving the Euclidean reconstruction problem with a perspective camera model by incrementally performing Euclidean reconstruction with either a weak or a paraperspective camera model. With respect to other methods that compute shape and motion from a sequence of images with a calibrated perspective camera, this method converges in a few iterations, is computationally efficient, and does not suffer from the non linear nature of the problem. With respect to methods that use an affine camera model (such as factorization) the method described below solves for the sign (reversal) ambiguity in a very simple way and provides much more accurate reconstructions results. We give a detailed account of the method, analyze its convergence based on numerical and experimental considerations, and test its efficiency with both synthetic and real data.
rec-affiter-long.pdf (581.66 Ko) Télécharger le fichier
inria-00590057 , version 1 (03-05-2011)
Stéphane Christy, Radu Horaud. Euclidean Shape and Motion from Multiple Perspective Views by Affine Iterations. IEEE Transactions on Pattern Analysis and Machine Intelligence, 1996, 18 (11), pp.1098--1104. ⟨10.1109/34.544079⟩. ⟨inria-00590057⟩
105 Consultations
204 Téléchargements
