Robot Stereo-hand coordination for grasping cylindric parts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1996
In this paper we present an algorithm to compute a set-point (i.e. a position to be reached by robot end-effector) automatically from conic features interactively selected by an operator onto the object. We then use a visual servoing algorithm to guide the gripper to its ?nal position. We have tested this algorithm in trying to open a valve with a 6 degree of freedom robot arm, using only visual information and without any model of the valve.
DufournaudHoraudQuan-BMVC98.pdf (167.14 Ko) Télécharger le fichier
inria-00590064 , version 1 (03-05-2011)
  • HAL Id : inria-00590064 , version 1
Radu Horaud, Yves Dufournaud, Long Quan. Robot Stereo-hand coordination for grasping cylindric parts. European Workshop on Hazardous Robotics (HEROS '96), Nov 1996, Barcelona, Spain. ⟨inria-00590064⟩
68 Consultations
102 Téléchargements
