Closed-form Solutions for the Euclidean Calibration of a Stereo Rig - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
In this paper we describe a method for estimating the internal parameters of the left and right cameras associated with a stereo image pair. The stereo pair has known epipolar geometry and therefore 3-D projective reconstruction of pairs of matched image points is available. The stereo pair is allowed to move and hence there is a collineation relating the two projective reconstructions computed before and after the motion. We show that this collineation has similar but different parameterizations for general and ground-plane rigid motions and we make explicit the relationship between the internal camera parameters and such a collineation. We devise a practical method for recovering four camera parameters from a single general motion or three camera parameters from a single ground-plane motion. Numerous experiments with simulated, calibrated and natural data validate the calibration method.
rufECCV98.pdf (266.63 Ko) Télécharger le fichier
inria-00590090 , version 1 (03-05-2011)
Gabriela Csurka, David Demirdjian, Andreas Ruf, Radu Horaud. Closed-form Solutions for the Euclidean Calibration of a Stereo Rig. 5th European Conference on Computer Vision (ECCV '98), Jun 1998, Freiburg, Germany. pp.426--442, ⟨10.1007/BFb0055682⟩. ⟨inria-00590090⟩
91 Consultations
100 Téléchargements
