Self-Calibration and Euclidean Reconstruction Using Motions of A Stereo Rig - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
This paper describes a method to upgrade projective reconstruction to affine and to metric reconstructions using rigid general motions of a stereo rig. We make clear the algebraic relationships between projective reconstruction, the plane at infinity (affine reconstruction), camera calibration, and metric reconstruction. We show that all the computations can be carried out using standard linear resolution methods and that these methods compare favorably with nonlinear optimization, methods in the presence of Gaussian noise. We carry out a theoretical error analysis which quantify the relative importance of the accuracies of projective-to-affine conversion and affine-to-Euclidean conversion. Experiments with with real data are consistent with the theoretical error analysis and with a sensitivity analysis performed with simulated data.
radu-iccv98-soumis.pdf (464.82 Ko) Télécharger le fichier
inria-00590095 , version 1 (03-05-2011)
Radu Horaud, Gabriela Csurka. Self-Calibration and Euclidean Reconstruction Using Motions of A Stereo Rig. 6th International Conference on Computer Vision (ICCV '98), Jan 1998, Bombay, India. pp.96--103, ⟨10.1109/ICCV.1998.710706⟩. ⟨inria-00590095⟩
112 Consultations
369 Téléchargements
