Bundle Ajustment -- A Modern Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2000
This paper is a survey of the theory and methods of photogrammetric bundle adjustment, aimed at potential implementors in the computer vision community. Bundle adjustment is the problem of refining a visual reconstruction to produce jointly optimal structure and viewing parameter estimates. Topics covered include: the choice of cost function and robustness; numerical optimization including sparse Newton methods, linearly convergent approximations, updating and recursive methods; gauge (datum) invariance; and quality control. The theory is developed for general robust cost functions rather than restricting attention to traditional nonlinear least squares.
Triggs-va99.pdf (705.4 Ko) Télécharger le fichier
inria-00590128 , version 1 (03-05-2011)
Bill Triggs, Philip Mclauchlan, Richard Hartley, Andrew Fitzgibbon. Bundle Ajustment -- A Modern Synthesis. Bill Triggs and Andrew Zisserman and Richard Szeliski. Vision Algorithms: Theory and Practice, 1883, Springer-Verlag, pp.298--372, 2000, Lecture Notes in Computer Science (LNCS), ⟨10.1007/3-540-44480-7_21⟩. ⟨inria-00590128⟩
421 Consultations
6709 Téléchargements
