Controlling Robots with Two Cameras: How to Do it Properly - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2000
In this paper we address visual servoing through a fixed stereo rig using an image Jacobian. Existing methods are based on the stacking of monocular servo image Jacobians, resulting in largely over­constrained control commands. In this paper we formally show that the epipolar constraint between two images can be taken into account explicitly. We then show that use of stereo significantly increases the quality of the servo task execution, especially where precision, ro­ bustness and smoothness of movement is concerned.
LEH-ICRA00.pdf (701.88 Ko) Télécharger le fichier
inria-00590135 , version 1 (03-05-2011)
Bart Lamiroy, Bernard Espiau, Nicolas Andreff, Radu Horaud. Controlling Robots with Two Cameras: How to Do it Properly. IEEE International Conference on Robotics and Automation (ICRA '00), Apr 2000, San Francisco, United States. pp.2100--2105, ⟨10.1109/ROBOT.2000.846339⟩. ⟨inria-00590135⟩
217 Consultations
167 Téléchargements
